JC_BOC bocanegra. Not running stage 2 anymore :-(
M1K3Y B
When you get the twintercooler will it need mapping again though or will it be effective on the same map?
jc_boc
Missing the CUPRA R!
Jul 18, 2008
9,304
7
Desborough
It will be fine with the current map but REVO will be releasing a modified map to accomodate these items for the lower running temps so the turbo can boost a bit more.
would it make that noise of gear changes with just a cat back, or is it more from the TBE
I would honestly be lying if I could tell you mate. I have not heard some one elses yet in the flesh so hopefully some one with the cat back can advise?
M1K3Y B
Sounds good mate!
mardon
Feel the DIFFerence
Sep 22, 2008
2,599
A bean bag
There is still power but the is a leaking of air from somewhere . I'll ring Seat Assist. Its ether the Re-circ or a burts boost pipe. Dont think its anything worse than that.
989
Am I right in thinking you can go stage 2 with the catback and intake? Then stage 2+ is for those with the twintercooler?
Revo Steve
shop.revotechnik.com
Mar 25, 2011
43
Hi,
Stage 2 software is for use with a turbo back and you can use either a replacement element filter or an ITG intake or similar. ITG inatek obviously the better option.
Stage 2+ file works wonders with turbo back, ITG intake and Forge Twintercooler. The twintercooler is a must for stage 2+ otherwise your temperatures sky rocket, resulting in the ECU pulling back.
Apr 9, 2009
989
Sorry yeah I'm not on the ball today ha
May have to skip out on stage 2 unfortunately due to the cost of the turbo back even with the discount :( I'll see how things pan out this month...
Revo Steve
Mar 25, 2011
43
Steve, will the FORGE induction kit also be fine? I already have one :confused:
I can honestly say I don't know. We haven't used one of these as yet. But being Forge I'm sure it will work just fine :D
You can let us know once you have the 2+ in :p
