LCR 210 MAF g/s log
Ovni_cupraR
Yellow Peril
Oct 25, 2008
131
Maidstone, Kent
Hello all, this is my first experience using vagcom and logging so I may have missed something.
I'm looking to get a stage 1 amd remap very soon so wanted to get an idea of the sort power she's running standard and any fault codes. I logged blocks 003 and 020 after doing some reading on here, 1st run was in 3rd gear, the 2nd run was in 4th gear.
Does everything look ok? I'm not sure what block 020 logs but I think 173.9 g/s peak in 3rd is about right for a standard lcr?
Saturday 26 March 2011 14:27:49
1ML 906 032 1.8l R4/5VT 0001
Group A: '003 Group B: '020
RPM Mass Flow Load Ign. Timing Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
TIME TIME
MARKER STAMP /min g/s % °ATDC STAMP CF CF CF CF
0.41 2440 20.14 12.5 30.8 0.01 0 0 0 0
1.21 2520 25 14.1 30 0.81 0 0 0 0
2.01 2600 25.56 14.5 30 1.61 0 0 0 0
2.81 2760 32.72 18.4 30.8 2.41 0 0 0 0
3.63 3040 89.03 99.6 19.5 3.23 0 0 0 0
4.43 3480 101.67 100 15 4.03 0 0 0 0
5.23 3920 115 100 18 4.83 0 0 0 0
6.04 4360 126.69 100 18 5.64 0 0 0 0
6.84 4760 140.5 100 16.5 6.44 0 0 0 0
7.75 5200 152.94 100 16.5 7.24 0 0 0 0
8.55 5560 166.17 100 16.5 8.15 0 0 0 0
9.37 5880 173.97 100 15.8 8.95 0 0 0 0
10.26 6240 169.97 100 20.3 9.86 0 0 0 0
11.16 6520 171.67 100 22.5 10.66 0 0 0 0
11.98 6240 5.61 7.8 9 11.58 0 0 0 0
12.78 5360 156.81 100 13.5 12.38 0 0 0 0
13.58 4800 8.39 7.5 4.5 13.18 0 0 0 0
14.39 3280 8.58 7.1 1.5 13.98 0 0 0 0
15.29 3160 8.08 5.9 2.3 14.87 0 0 0 0
16.18 3000 7.81 5.9 2.3 15.69 0 0 0 0
16.98 2880 7.17 5.5 1.5 16.58 0 0 0 0
TIME TIME
0.39 3000 59.42 52.5 27 0.01 0 0 0 0
1.3 3160 91 100 15 0.81 0 0 0 0
2.1 3360 92.78 100 14.3 1.7 3 0 0 0
3.11 3600 102.28 99.6 18 2.61 3 0 3 3
4.02 3840 108.19 100 17.3 3.51 2.3 0 3 3
4.82 4040 112.36 100 16.5 4.42 2.3 0 2.3 2.3
5.62 4200 119.78 100 16.5 5.22 1.5 0 2.3 2.3
6.44 4400 124.97 100 17.3 6.02 1.5 0 1.5 2.3
7.24 4560 127.86 100 17.3 6.84 1.5 0 1.5 1.5
8.04 4760 136.25 100 17.3 7.64 0.8 0 0.8 1.5
8.84 4920 140.22 100 16.5 8.44 0.8 0 0.8 0.8
9.65 5080 145.56 100 16.5 9.25 0 0 0.8 0.8
10.45 5280 149.78 100 18.8 10.05 0 0 0 0
11.25 5440 160.61 100 15.8 10.85 0 0 0 0
12.16 5640 162.44 100 16.5 11.67 0 0 0 0
13.08 5800 167.97 100 16.5 12.66 0 0 3 0
13.99 5960 169.39 100 18 13.48 0 0 3 0
14.77 6080 154.42 84.7 18.8 14.37 0 0 2.3 0
15.59 6200 171.67 99.6 19.5 15.19 0 0 2.3 0
16.39 5960 6.78 6.7 7.5 15.99 0 0 2.3 0
17.19 4720 11.47 8.6 3.8 16.79 0 0 0 0
18 4000 9.25 6.7 4.5 17.59 0 0 0 0
18.8 3920 23.5 13.3 27.8 18.4 0 0 0 0
19.7 3880 37.14 17.6 36 19.3 0 0 0 0
20.61 3800 7.78 6.7 27 20.11 0 0 0 0
21.42 3760 10.94 7.8 35.3 21.01 0 0 0 0
JamJay
California Bound
Code:
	TIME					TIME
Code:
	TIME					TIME
That should sort it out for you, if you ever want to post Excel data then wrap the text in 'code' tags. 173.97g/s equates to around 220bhp which is about right to be honest. Correction factors are also ok as they are, worry if that ever goes above 6 but now everything looks healthy :)
Ovni_cupraR
Yellow Peril
Oct 25, 2008
131
Maidstone, Kent
Cheers for doing that :) much easier to read now. I'm not sure what correction factors are i just knew to log 003 and 020 together, still learning how to use vagcom.
thanks
JamJay
California Bound
As far as I know CF's are timing retard which basically you don't want too much off as the car is trying to prevent engine knock in the combustion chamber which over a period of time can be destructive. You should see generally under normal driving conditions no more than an average of 2 degrees of timing retard, you have a max of 2.3 so you are fine.
To work out BHP on this engine via g/s readings then take the highest g/s number and divide it by 0.8. Alternately take the highest g/s number and multiply it but 1.275 which gives a slightly higher figure. I usually do both and guage the bhp by somewhere between the two numbers.
