maxthomas
Evening all,
Help needed
I have had this problem on and off for a few years.
I start the car, the EPC light is on and when pressing the accelerator the car stutters, I turn the ignition off, then on again and the light appears again (but the pedal works fine and drives ok).
I had the throttle body changed after this showed on the VAG machine, then 1 month later, EPC light again and the body was tested and was not at fault (although the VAG machine said the body was to blame)
Somebody at my local garage decided to take apart the pedal and put it back together and this solved it for 6 months.
Now the Light is back and is getting worse, the car now doesn't always start second time, its now 3rd or 4th.
Anybody had similar problems, or anybody from the Newton abbot/Devon area have a machine they can test it on?
Thank you ever so much
Max
Help needed
Max
