Mattgriff90
Shot in the dark but ive got a leak from front wheel arch, could this solve it? Thought i would check before pulling things apart.
I seem to have a water leak in the boot too, but its on the passender side, not the drivers.
The carpet that covers the wheel arch is wet at the bottom but when I pull the carpet back its dry behind it.
Has nayone else had this problem?
cheers
Hi nc30rider
I have got to the last stage as in your photo, but cannot find the female end to fix it. Where should it be? Did you have trouble locating it first time around? Where can I buy the little plastic plug that holds the carpet as I have accidently snapped it when taking it off.
