Show us your Boost Gauge installs!
Gooner_Mike
Teaching the kids
Jan 20, 2008
4,363
Hampshire
www.facebook.com
Hopefully ill find something, if not ill get a welding rod from work haha
i can see me just routing it out the bonnet and through drivers window:lol:
This is how I did mine. If you open the passenger door and remove the "fuse cover" next to the air vent, the grommet is just behind the soundproofing. You can take the glovebox out too and route the pipe towards the central instrument panel.
Have a look here: http://www.seatcupra.net/forums/showpost.php?p=2539424&postcount=905
350
From what I understand it is the pipe that is coming out from under the engine cover that you need to tap into..
The pipe on the drivers side, near the coolant bottle if you get me?
EDIT* You don't 'T' into anything, you need a fitting to put the hose onto..
350
http://www.bearingboys.co.uk/HT1418_Hosetail-9807-p
There's the link to the part you need to tap into the intercooler pipe for boost pressure. Also, it'd be a good idea to fit PTFE tap when you screw it in..
And there is a picture of how it needs to be fitted; although when I do mine, I'll be putting it underneath the pipe so it can't be seen!
wazza16
Mr.Waz
Aug 19, 2010
241
Arbroath
when installing oil temp Guage do i need to buy a sandwhich plate so i can take my oil pressure line from it? im looking at prosport Electrical gauges boost and oil temp! CHeers
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
If you look at the oil filter housing you will see a small allan grub screw on the top of it, remove that and screw the oil temp sender into it. Job done :)
