i have two faults code now wich befor i had 4 after fitting a new maf witch i thought would fix this it has not
the fault codes are
16487 P0103 Mass or Volume Air Flow Circ High Input
17840 P1432 Sec.Air Inj.Valve Open
now the last one could be because i have not got a n114 valve on at all or a plug on it not even a resitor the wires have just been cut and taped up and tucked away
would this efect things like the above code mabie
any help at all on this would be grate ,just trying to shed some light
also the traction control light is on but not the eml and it failed the mot yetaday just on high emissions and it will not drive right as it will not let you drive it hard and hit big boost it just kinnda stutters
the fault codes are
