so 330 should be a good number to aim at with our setup, and torque wise im after 330 as well we shell see what our different mappers can do
Forget peak torque and bhp figures, what your looking for is sustained torque over a large rev range.
Check out my RR hybrid print out here.
http://www.seatcupra.net/forums/showthread.php?t=246823&highlight=wild+willy's
One really important mod for these hybrids that made 10bhp and big difference in spool and torque was a 3 inch tip. Forget the forge and samco silicon tip, thier bores are too small. 330bhp is big turbo territtory and you won't see any decent big turbo install sucking through a 2 inch pipe, your maff and air filter are 80mm for a reason.
It is the same size as the inlet on the turbo true and this is where people dismiss the mod. Air flow is what its all about and each bend offers a significant resistance to the flow of air.For max hybrid benefit consider the following.Thats a cracking curve, power band is massive, regarding the TIP, at the end of the day its still the same intake size on the turbo.
I see you are running the Modshack housing, does this not make all the MAF reading a bit screwy?
the turbos in catterick im in cov and it looks like coated inside yeah. when i get back monday i will see if they match up and if mine is ok, or if need to grind anything, im not to bothered if it touches, i got some thermotec exhaust wrap which is expensive stuff so will put that beeween turbo and mani.
got to wait here till mon as i need my injectors before i go back up the road and finally start the rebuild whens your rods being fitted ?
i think your going to be finished 1st lol, i still waitin on engine, cant wait to get it back on the road now, been so long, went to fit rear arb last night and couldnt get it hooked onto the back, will have another go on monday i think,
what cost is the map costing you? and is it a custom map?
well hopefully have all my stuff from forge monday, then drive back to catterick that afternoon and im hoping that when i get up that way engine will be ready, once i get engine will take a few days to fit to car, will get it booked in for a mot and hopefully start the mapping on the 18th...
how longs the mapper said will take to do your car and you need your car when you leave the country,
