Dunt know if these are of any use:
1.
http://www.a2resource.com/electrical/electrical.html
or 2. Pre 90's fuse box detaills
Fuses
Fuse No. Description Ampere Rating
1 Radiator cooling fan 30
2 Brake lights 10
3 Cigar lighter, radio, clock, interior lights,central locking 15
4 Emergency flashers 15
5 Fuel pump (gasoline engines) 15
6 Open -
7 Taillights, parking lights, side marker lights (left side) 10
8 Taillights, parking lights, side marker lights (right side) 10
9 Headlights (high beam, right) high beam indicator light 10
10 Headlights (high beam, left) 10
11 Windshield wipers/washers 15
12 Heated seats, electric outside mirrors 15
13 Rear window defogger, heated inside rear view mirror 15
14 Heater blower glove box light 20
15 Back-up lights, automatic transmission console light 10
16 Horn 15
17 Knock sensor control unit (gasoline engine) 10
18 Dual horn, coolant level and temperature warning light 15
19 Turn signals, brake warning light 10
20 License plate lights 10
21 Headlights (low beam, left) 10
22 Headlights (low beam, right) 10
Relays
Relay No. Description
1 Open or Digifant relay
2 Fuel pump (gasoline) / Glow plugs (diesel)
3 Seat belt warning
4 Upshift indicator (1985-1987)
5 A/C relay
6 Dual horns
7 Open
8 Load reduction
9 Open
10 Intermittent wipers
11 Rear wiper
12 Turn signals, flashers
13 Open or power windows
14 Cooling fan after-run (except 16-valve)
15 Passive restraint (1988, 1989) or ABS/coolant temperature relay
16 Idle air stabilizer
17 A/C thermofuse or ABS
18 Coolant level indicator
19 Power windows
20 Heated seats (left)
21 Heated seats (right)
22 Oxygen sensor system power supply (US cars w/CIS) / Automatic transmission relay
23 Power window fuse (30A)
24 Glow plug fuse (Diesel-50A)
List of relay numbers / descriptions:
1 = Carb inlet manifold heater relay
2 = Fuel pump relay (MK1 & Early MK2/Rocco K-Jet)
5 = Shift light and MPG gauge
15 = radiator fan
17 = x-over relay, 40amp?
18 = x-over relay
19 = front wiper intermittant relay
20 = rear wiper non-intermittant relay (when you push the stalk forward, it'll only wipe once, no intermittant!)
21 = hazard/indicator relay
30 = MK3 (GTI 8v or 16v?) ECU relay
32 = MK2 digifant ECU relay
36 = seatbelt warning relay (possibly headlight warning too?)
53 = misc equipment ignition switched relay (horn, fogs, leccy windows etc)
67 = MK2 16v/ MK3 VR6 fuel pump relay
72 = rear wiper intermittant relay
74 = carb decelleration cut-off
80 = MK2 digifant fuel pump relay
99 = front wiper variable intermittant relay
109= VR6 ECU relay
133= aircon relay
167= MK3 & MK2 16v fuel pump relay
or 3. Post-90 Fusebox Fuses & Relays:
1 Headlight, low beam, left 10
2 Headlight, low beam, right 10
3 Instrument panel lights, license plate lights 10
4 Glove compartment light 15
5 Wiper/washer 15
6 Fresh air blower 16-valve only: Air conditioning 20
7 Taillights, side marker light, right 10
8 Taillights, side marker light, left 0
9 Rear window defogger 20
10 2.0 16-valve only: Fog lights 15
11 Headlight, high beam, left,High beam indicator light 10
12 Headlight, high beam, right 10
13 Horn 16-valve only: Radiator cooling fan 10
14 Back-up lights, washer nozzle heaters 10
15 2.0 16-valve only: Engine electronics, stabilizer valve, cold start valve 10
16 Instrument panel warning lights, 16-valve only: Multi function indicator 15
17 Emergency flasher switch, turn signals 10
18 Fuel pump, oxygen sensor heater 20
19 Radiator cooling fan, air conditioning 30
20 Brake lights, cruise control 10
21 Interior lights, digital clock 16-valve only: Luggage compartment light,multi function indicator, central locking 15
22 Radio, cigarette lighter 10
Relays
1 Air conditioning
2 Open
3 Digifant control unit (except 16-valve)
4 Load reduction relay
5 Low coolant level control unit or Open
6 Emergency flashers
7 Rear Wiper
8 Intermittent wipers
9 Seat belt warning system control unit (possibly headlight warning too?)
10 Fog lights
11 Horn
12 Fuel pump (except diesel)Glow plugs (diesel)
13 Radiator cooling fan after run (except 16-valve)2.0 16-valve: Starter interlock relay
14 Automatic trans., coolant temperature indicator,starter interlock relay (except 2.0 16-valve)2.0 16-valve: Radiator cooling fan after run
15 ABS pump relay
16 ABS relay
17 Heated seat control unit, driver
18 Heated seat control unit, passenger, or power seat circuit breaker
19 Automatic transmission
20 Open
21 Power window relay, ABS hydraulic pump fuse
22 ABS valves fuse
23 Air conditioning, power seat fuse
24 Power window fuse
