Few Logs
mat_106
98
Chesterfield
did a few logs the other night, to see if my car is running ok. just wondered if anyone can tell me if it is or not cause i dont have a clue!
Gaz of here did them for me (cheers mate) and he said the third one messed up so i havent got that one yet but can these tell you anything?
Code:
Monday	7	June	2010	11:22:14
6K0 906 032 AA 		1.8L 20VT EU3       0002
	Group A:	'004				Group B:	'020				Group C:
		RPM	Voltage	Temperature	Temperature		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
	TIME					TIME					TIME
MARKER	STAMP	 /min	 V	°C	°C	STAMP	 CF	 CF	 CF	 CF	STAMP
	0.4	2760	13.93	83	26	0.01	0	0	0	0
	1.21	2920	13.86	82	24	0.8	0	0	0	0
	2.22	3160	13.86	83	24	1.71	0	0	0	0
	3.01	3400	13.86	83	24	2.61	0	0	0	0
	3.9	3640	13.93	83	24	3.5	0	0	0	0
	4.7	3880	13.79	83	26	4.3	0	0	0	0
	5.61	4120	13.79	84	27	5.12	0	0	0	0
	6.51	4320	13.72	83	27	6.11	0	0	0	0
	7.31	4520	13.93	83	29	6.91	0	0	0	0
	8.11	4680	13.93	84	30	7.71	0	0	0	0
	8.91	4840	13.93	84	30	8.51	0	0	0	0
	9.71	5000	13.86	84	30	9.31	0	0	0	0
	10.51	5160	13.86	84	31	10.11	0	0	0	0
	11.31	5280	13.86	84	32	10.91	0	0	0	0
	12.11	5400	13.86	84	32	11.71	0	0	0	0
	12.91	5480	13.79	84	32	12.51	0	0	0	0
	13.71	5600	13.93	85	33	13.31	0	0	0	0
	14.6	5680	13.79	85	33	14.11	0	0	0	0
	15.4	5760	13.93	85	33	15	0	0	0	0
	16.31	5840	13.86	85	33	15.91	0	0	0	0
	17.11	5880	13.86	85	33	16.71	0	0	0	0
	17.91	5640	13.86	86	33	17.51	0	0	0	0
	18.71	4680	13.93	87	33	18.31	0	0	0	0
Code:
	Group A:	'115				Group B:	'118				Group C:
		RPM	Load	Absolute Pres.	Absolute Pres.		RPM	Temperature	Load	Absolute Pres.
	TIME					TIME					TIME
MARKER	STAMP	 /min	%	 mbar	 mbar	STAMP	 /min	°C	%	 mbar	STAMP
	0.01	2560	13.5	980	1020	0.39	2560	33	0	1010
	0.89	2560	19.5	980	1010	1.38	2560	32	0	1010
	1.8	2600	35.3	980	1000	2.29	2640	30	95.3	1140
	2.77	2760	110.5	2160	1450	3.17	2840	27	95.3	1670
	3.57	2960	143.6	2200	1880	3.97	3040	26	95.3	2070
	4.37	3160	161.7	2260	2140	4.88	3320	24	93.7	2220
	5.28	3440	172.2	2320	2270	5.68	3520	24	93.7	2270
	6.18	3680	169.2	2310	2250	6.58	3800	25	95.3	2230
	6.98	3920	163.9	2300	2180	7.38	4040	26	95.3	2150
	7.88	4160	160.9	2230	2120	8.29	4280	27	95.3	2080
	8.69	4400	157.1	2180	2040	9.17	4520	28	95.3	1990
	9.59	4600	151.9	2110	1980	9.99	4680	29	95.3	1940
	10.39	4800	148.1	2040	1920	10.79	4880	30	95.3	1890
	11.19	4960	144.4	1970	1870	11.59	5040	30	95.3	1840
	11.99	5120	141.4	1930	1820	12.39	5200	30	95.3	1800
	12.79	5280	137.6	1900	1810	13.19	5320	32	95.3	1780
	13.59	5400	133.1	1850	1770	13.98	5440	32	95.3	1760
	14.39	5520	128.6	1830	1750	14.78	5600	32	95.3	1740
	15.18	5640	127.8	1800	1700	15.58	5720	33	95.3	1690
	15.98	5760	125.6	1770	1670	16.38	5840	33	95.3	1660
	16.78	5880	123.3	1760	1650	17.28	5920	33	95.3	1640
	17.68	6000	122.6	1720	1600	18.08	6040	33	95.3	1630
	18.58	6080	119.5	1700	1620	18.98	6120	33	95.3	1600
	19.38	6160	117.3	1670	1600	19.77	6200	33	95.3	1590
	20.29	6280	117.3	1640	1590	20.69	6320	33	95.3	1570
	21.09	6360	115.8	1620	1570	21.49	6400	34	95.3	1570
	21.89	6400	114.3	1600	1560	22.29	6440	34	95.3	1560
	22.69	6480	112.8	1580	1570	23.09	6520	34	92.5	1550
	23.49	6560	112	1580	1550	23.89	6600	34	93.3	1560
	24.29	6600	110.5	1580	1560	24.69	6640	34	93.7	1550
	25.18	6680	109.8	1580	1550	25.58	6720	34	94.5	1540
	25.98	6760	108.3	1090	1540	26.38	6200	34	0	1400
	26.78	5320	6.8	990	1170	27.18	5360	33	0	1100
	27.68	5280	9.8	990	1080	28.17	5240	33	0	1070
	28.57	5160	9.8	990	1070	29.07	5080	34	0	1060
	29.58	5000	9.8	990	1060	29.98	4920	34	0	1060
	30.38	4840	9.8	990	1060	30.78	4760	34	0	1060
	31.28	4680	9.8	990	1060	31.67	4640	34	0	1050
	32.08	4600	9.8	990	1050	32.57	4560	34	0	1050
	32.97	4520	9.8	990	1050	33.37	4480	34	0	1050
	33.77	4440	9	990	1050	34.17	4440	34	0	1050
	34.57	4400	9.8	990	1050	34.97	4360	34	0	1050
	35.37	4320	9.8	990	1040	35.77	4280	34	0	1040
	36.17	4240	9.8	990	1040	36.57	4240	34	0	1040
	36.97	4200	9.8	990	1040	37.47	4160	34	0	1040
	38.67	4080	9.8	990	1040	38.27	4120	34	0	1040
Nov 2, 2004
9,335
South Wales
Your car is struggling to make the requested boost so it suggest you have a boost leak.
N75 duty is pegged at 95.3, a sure sign of a boost leak.
004 is a waste os time to log imo. 002 and 003 are much better imo.
mat_106
98
Chesterfield
oh right cheers mate! ive always thought ive had a boost leak. i have been recently messing about with my split-r . it was on the wrong way so i put it on the right way and have it about 22 clicks.
is my n75 working then? just need to replace all the boost pipes or?
and i dont have a clue how to log lol. gaz of here did it for me
Bakkums
61
My car is standard and I have these logs (number 115) You can compare these.
Code:
	Group A:	'115
	TIME
Marker	STAMP	 /min	%	 mbar	 mbar
	0,35	1640	72,2	1640	1030
	1,25	1800	88	1720	1250
	2,05	2000	97,7	1860	1430
	2,96	2240	112	1970	1630
	3,76	2480	128,6	2060	1810
	4,54	2760	143,6	2190	2010
	5,34	3080	151,9	2160	2080
	6,14	3400	160,9	2130	2200
	6,94	3720	151,9	2090	2110
	7,74	4000	150,4	2080	2100
	8,54	4280	148,1	2030	2080
	9,34	4520	147,4	1980	1990
	10,14	4800	146,6	1950	1970
	10,94	5000	142,9	1920	1920
	11,74	5240	137,6	1880	1890
	12,56	5400	131,6	1840	1850
	13,45	5640	127,8	1800	1810
	14,25	5800	124,1	1780	1760
	15,05	5960	120,3	1720	1720
	15,85	5520	13,5	990	1240
	16,65	4200	12,8	990	1100
	17,64	2760	12	990	1070
	18,44	1720	15,8	990	1040
	19,24	1160	15,8	990	1030
mat_106
98
Chesterfield
I'm remapped mate ( stage 1) and I also I dunno what I'm looking for lol. Just need to sort the leak out, is my n75 working then? Not broke?
Bakkums
61
First replace or check your pipework, I think just as Phil that you have a leak.
Question: What does Part throttle mean ?
I have Full throttle.
Code:
Group B:	'005
	RPM	Load	Speed
TIME
STAMP	 /min	%	 km/h
0,75	1680	79,7	40	Enrich.
1,65	1880	93,2	44	Enrich.
2,56	2120	106,8	50	Enrich.
3,36	2360	118,8	54	Part Throttle
4,16	2640	136,1	62	Part Throttle
4,94	2920	148,9	68	Part Throttle
5,74	3240	158,6	76	Part Throttle
6,54	3560	155,6	84	Part Throttle
7,34	3840	151,9	90	Part Throttle
8,14	4160	149,6	98	Part Throttle
8,94	4400	148,1	104	Part Throttle
9,74	4640	146,6	112	Part Throttle
10,54	4880	145,9	116	Part Throttle
11,34	5120	141,4	122	Part Throttle
12,14	5320	135,3	128	Part Throttle
13,05	5520	130,1	134	Part Throttle
13,85	5720	126,3	138	Part Throttle
14,65	5880	122,6	142	Part Throttle
15,45	6280	42,1	146	Idle
16,25	4840	17,3	144	Idle
17,15	3440	15,8	142	Overrun
18,03	2200	13,5	140	Overrun
Bakkums
61
That doesnt look like a standard car to me. Requested 1.1bar.
I bought my car a few weeks ago and they told me it wasn't chiped.
How do I know if it is chiped ? Can I look for it with vag-com ?
I already thought it was quicker dan normal. Maybe it is chiped then :blink:
What kind of boost runs a standard Ibiza Cupra ?
Bakkums
61
Around 0.5bar, yours is requesting nearly 1.2 bar in places.
Hmmmm that is a lot of difrence, it is tuned than. I found it aquard that i was as fast as a Leon Cupra (FR)
I go and check my 0-60 time soon then. Thanks
