breather system part number?
Pyro
hello guys does any1 know the part number for these two pipes???
jonesy118
388
Cheshire
First picture is: 06A133783G if it's the 90 deg bend you need.
second picture is: 06A103213AF if a cupra 180, if it's a cupraR (210 or 25) you need 06A103213AK
Just replaced mine with some 19mm silicone instead
Pyro
cheers buddy its 180 AUQ might just replace with silicone but there all bends and whatnot would like a silicone kit that replsaces but cant find one anywere
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
sam i had the same pipes split look!!!
best thing to do is get a catch can and get rid of all that pipe work, the second pic, that pipe cost £40 thats more that a catch can
sambryant
Mar 26, 2009
4,848
Bristol
mines a 15mm toyo can, most are 15mm and you need to make them fit. i heated up some 8mm silicone and slid it over the outlets, nice tight fit with the 19mm hose now :)
jonesy118
388
Cheshire
the second pipe can easily be swapped for a 19mm silicone straight length. Here's mine. Failed upper and lower breather so far now!!
jonesy118
388
Cheshire
volks bits on eBay. Gone up a bit since I got mine.. mine was £20 delivered I think. Much more rigid than the original
oldskool
I have the lower on in the classifieds if youre interested, just sold the top one
Pyro
legend cheers mushty ill be ordering that payday :D so i need a little bit of 8mm and how many meters of 19mm????
sambryant
Mar 26, 2009
4,848
Bristol
you can use the hose that they supply if you like m8, i used my silicone to make it a really tight fit, but as i said the stuff they give you will do the job
oldskool
oi saw that erlier actuly but had to go out so couldnt PM ya how much wsa it again??
check the price in the classified, dont want to be breaking the rules on here, especially now im up to 200 posts;)
