Lum aboot done
Well, what a bastid of a job that was.
I knew it was going to be difficult.
Th problem is not the job its just the access.
As the DP and CAT sections are 7 years old the bolts were in a bad way.
I tried everything but in the end I hire a reciprocating saw and cut the fecker off!!
Thankfully the Lambdas cam out easy enough without stripping threads, these were logged prior to removing and all was well.
I got quite a bit done today, the saw was def the turning point.
I still had to drop the sub frame to allow the OEM DP out and the new one back in.
So the new DP and de CAT are in and all but one nut is tightened.
I couldn't find my new DP to Turbo gasket so I reused the old one with plenty paste on it, same with the other joints.
Fit seems good so far.
I'll see what I can get done tomorrow morning.
I've got to go offshore tomorrow so the car won't be at the national day.
TBH it was going to be a massive rush anyway and really don't enjoy working on my car when rushing anyway.
The map has been written, I ave the 4 BAR FPR and the exhaust will be on.
When I get back I'll get the map on.
The first stages are to get the map on and do some logging to see how happy the car is.
There might be some further tweaking to carry out.
Leave the car to adapt for 200 miles ish then some more tweaking.
Looking forward to the big grin associated with a freshly mapped car
