Craig car looks fine at that height mate, remember fuel in the tank etc will effect ride height a little. Mine tends to move about 10mm and the rear depending on whether its full or empty.
Spray job looks mint I need a new rear bumper to get rid of the parking sensors but i just shelled out on Proxes so thats on hold for now. If it werent for the seats you be hard pressed from looking at your car to tell whether it was a GTi or not.
Ouchie. Probably easiest to get down sthe scrappy and cut that section out on a solid one.
That's the plan mate. It's got a few holes in the rear footwell that'll get welded up too. It's only a run around so not really fussed how it looks, it just needs to pass an MOT!
Theres about 3/4 tank of fuel in there at the minute. Will have to see if it scrubs with a couple of people in the back, but I think it should be fine.
Im needed 2 front tyres aswell and brakes, but I think Im getting a 280mm front set-up from a valver.
Im really happy with the spray job. Isnt a 'perfect' match but is really really close. Was only meant to be getting from the door back done but when he started the dents on the wing etc stood out so he just fixed those aswell.
Seats are next on my list I think.
Have you painted you indicators or smoothed?
sprayed them over and moved the bulb unit to the bottom and installed them into the bottom of the bumper fogs so it stealth indicators all legal and only orage is when they are on thru the fog lense and fog still work : )
:headhurt:lol for off road use only and only when i chnaged the clutch as i can feel it slipping a little:(
35 to start to get engine used to it as dont want to stress it and then ill go higher but no point until i get strenghen internals lol
you going forged? maybe you could look into getting a turbo kit :p going for 700-800 on ebay.
