I have recently fitted Forge Motorsport's latest twin inspired product, the Twintake and I want to share my thoughts on the kit.
Those in the know will know I've had more than my fair share of intakes on my Mk2 Leon Cupra TFSI over the past year or so. I've not been entirely satisfied with some of the other solutions available and have tried a few different kits, as well as stock inc Carbonio, Dbilas intake and the ITG Maxogen foam intake. Forge have arrived fairly late to the market, but is their solution any better than the competition in my view?
First I'll make some observations about what I've ran before and then move on to my feelings about the Forge kit:
CARBONIO COLD AIR INDUCTION
The Carbonio is nothing more than a cold air feed to the stock airbox/engine cover, the resulting advantage is quite small. The car has a bit more of an induction sound to it, coupled up with a good aftermarket panel filter such as a Green or K&N then a few extra hp can be delivered a little more torque but overall the improvements are minimal and mostly aesthetic under the bonnet. High power Stg2+ cars will ultimately suffer from the restrictive airflow the stock airbox can provide. Drivability is probably much better but it will shave off quite a bit of performance on Stg2+ cars.
DBILAS INTAKE
The Dbilas replaces the stock airbox/engine cover, and is the first proper intake kit I tried, it utilised a die-casted airbox in the stock location above the radiator. This airbox has a small panel filter enclosed, which did seem a little restrictive yet it did remain quite cool and produced a healthy increase in power, at least 15hp on my Stg2+ setup.
While it didn't really offer much more than a slightly louder induction sound compared to the Carbonio it did produce some brief waste-gate sound when lifting off boost.
I wasn't a fan of the fitment on the Dbilas kit, it was designed primarily for the Mk V Golf as were many early intakes and there wasn't much flexibility in it for fitment to other applications such as the Cupra. The take off pipe was poorly located and this in-turn caused the airbox to sit too high under the bonnet this in turn lead to it being sat at the wrong angle for the correct airflow. The kit being almost entirely cast was quite heavy in comparison to other intake kits.
ITG MAXOGEN INTAKE
The ITG Maxogen intake kit has probably been the kit of choice for most Mk2 Leon Cupra owners of late and I got myself one last autumn. This is widely thought of as one of the better developed solutions. ITG have engineered a good fitment on the most part avoiding some of the problems with other kits that were primarily designed for the VWs, this was designed with the Cupra in mind from the outset.
The power increases with the ITG are very good indeed, my own Stage 2+ Cupra gained at least 20hp some have seen much more depending on the remap used. Having had this intake on a few months I can say it works very well delivering performance, but it has some downsides I've found difficult to live with. Its very loud, now I don't mind a nice induction noise but the open foam filter sock is extremely loud. Drowning out even my APR exhaust which is no mean feat, it might draw some unwanted attention its pretty east to tell your gunning it for example.
Its also not what I would call a pretty intake, and is what could be described as a little heath robinson in its presentation, some would argue its function over form. But then if we are honest we all still like this stuff to look good as well as purposeful, especially when were parting with the thicker end of 300 notes.
The large Maxogen foam filter is crammed in front of the battery box and an impromptu airbox arrangement is made using a foam divider. This to me doesn't really work that well, again its not very tidy and I am not convinced it blocks the intake from the engine bay temps quite as well as it could, in fact many people have modified it with ducting from the fog light enclosure. But this in turn also allows more moisture ingress directly to the filter, especially if you were to accidentally go through deep puddles or travel on very wet roads.
Having lived with it for several months I didn't like the way the turbo warbled even under the lightest of loads with my main concern being how laggy the car felt unless you nailed it everywhere. I went to Oulton Park earlier this year for a track day the ITG made sense when it was screaming around the race circuit near the top of the rev band, in fact that was the one of the times it really excelled.
However under general driving conditions I felt it under-performed. As an example, my daily commute is mainly made up of town driving with some fast A-road if the rush hour traffic allows.
I found the car felt laboured at slower speeds and was slow on the uptake unless you were to drop it a cog or two. This is something I rarely had to do before, the car would pull strongly from low revs with little effort and lets be honest when your in the rush hour you tend to prefer to just let it drag itself along in one or two gears.
ITG's focus on racing experience has developed a kit that provides exceptional high end performance and power but it isn't an all round package that I personally believe a fast road package requires and I found the driving experience with the ITG more tiresome as a result.
I also found that fuel economy suffered considerably with the ITG fitted compared to the previous kits probably because I was having to stir the gearbox more often around town to get the car to sparkle a bit more.
Forge Twintake review see next post.
DBILAS INTAKE
ITG MAXOGEN INTAKE
