Hey mate hows it going did you go to spring fest and if so what did you make, i did see a Black leon making 13.5 not sure if that was you tho, at its a OEM look :)
Re: buch leon cupra r 400+ as it stands UPDATE PG 12-PICS
the whole under chassi is diferent on the leon 4wd you would be better off buying the 4wd leon and putting ur engine in there . and then swapping ur dash etc for right hand drive would cost£££££££ to convert a fwd leon to 4wd cheaper to do the engine swap .. as for the meet mate its on the a20 in sidcup
Do they even do these Leons in the UK?
Nope don't think they do tbh, but swaping engine dash etc would be easyer than making a lcr 4wd
Nope - Europe only.
To convert a Leon to 4WD you'd need to find a donor Audi S3 or TT, cut out the rear floor section (from fuel tank to end of boot) and weld it into the leon then use the S3/TT drivetrain. It has been done plenty of times on Golfs in the US.
Nope - Europe only.
isen`t better to bay on from germany with broken engine or little damage and built it from LHD to RHD?
been ages since i posted on this. my car is gonna be in next months redline mag so guys you better buy a copy.
cars currently at backdraft getting finished off. got the new kw clubsports on a finished map rs4 maf and bigger injectors. oh and the racelogic traction control system woohoo
I've been interested in getting the Race logic traction control system fitted, spoke to Mark ages ago when I bought my turbo kit... should be interesting to see how you get on with this.
this looks like a very nicely put together motor, plus the engine bay looks well looked after and tidy too.
Have you done anything with the brakes yet mate? If not, will you be doing? I can imagine that you could do with getting something better than the standard Brembos with all that power!
