to clarify,
i DID NOT, and never have said that you are always running some boost. That is total cr@p.
i do not want to be associated with such comments, in fact i replied to muttley stating that he has missunderstood the theory behind turbos making an engine more efficient.
Similair to that an engine is more efficient when it is accelerating slightly rather than at a constant speed. Some people think this means its using less fuel, but this is incorrect. Its more efficient in that the output is greater in proportion to input. (ie the power output/fuel is greater) but this is not to say its a more efficient way to drive. In order to make this work for you it would require that you slowely accelerate, then coast then accelerate then coast, which is how they drive on ultra fuel efficient runs for records etc, but its not how you should drive on the road.
Turbos were originally designed for efficiency, but thats not to say when on boost you will get better mpg, in fact quite the opposite as it allows you to run a smaller engine for 95% of the time but have the power when needed of a larger engine. (eg overtaking)
and finally, "disconnecting / turning off the N75 will increase efficiency"... well not directly. It will not increase the efficiency of the engine, but it will effect how you use the engine as it will limit how much boost you have available. You can do exactly the same thing by modifying how hard you press the accelerator and so its really for people that have no control over their right foot
As ibizacupra has said, like for like driving, eg cruising there will be no difference.
(although i will conceed that anyone who has or has used a boost guage will have a better understanding of how and when boost comes in)
Think you've hit the nail on the head there andy - people getting confused with using less fuel and being more energy efficient. Nicely explained!
The TDi letters in his signature suggests diesel rather than petrol...
Haha at least one of us is awake today matey!
Still wondering if anyone has tried leaving N75 disconnected for a while and if you get an EML?
I'm seriously considering trying to wire a switch to it in the dash so can drive normally with it disconnected and flick the switch when I fancy a bit of spirited driving!
