I wasn't 100% sure about that one but that would make sense.
Alex
I might be wrong, I am putting 2 + 2 together. But as you say, it would make sense.
Alex
Mine was bad a while ago http://www.seatcupra.net/forums/showthread.php?t=214944
Kept getting sensors replaced by Liverpool SEAT and a week later it would be the same. Took it to IMG & they replaced a fuse & wiring loom and touch wood i havent had a problem since. I havent even had the DPF light on
There is an independent VAG garage on Lingholme Street near the ASDA. I'd try them if i were you.
Why that one? Do you have there number?
