nah, just busy getting the engine all running like new mate, so its on the to do list. However looking at it, I think I will just get it done with the cam belt at the end of the year.
took 5 litres on my LCR. But that was drained properly including heater matrix etc.
Alright guys, I'm also changing the coolant in mine as the 'mechanic' i took it to kindly polluted my G12 with god knows what? Any way, anyone know how to make sure i've compleatly drained the system i.e. there's none left in the heater, oil cooler etc, and am i likley to get any airlocks when i refill???
Thanks in advance....
Make 100% sure you get the right type of coolant !!!
Think it's referred to as G12, it's reddy/pink in colour. You should double-check first. It probably says on the expansion bottle somewhere.
If you use the wrong stuff it can react with what's left inside and clog up your cooling system
I would normally say simply drain with the heater for cabin on.. then refil.
But in order to be sure to have got rid of all the coolant in your case, id say that draining it, then filling with water.. running for a little bit with heater on max (to ensure there is circulation for all parts) then drain a second time before filling with with the correct coolant wouldnt be a bad idea.
Depends how thorough you want to be,
PS i got some G12 from the dealer 2 weeks ago and it was in 1.5litre bottles. So this is enough for 6 litres once mixed with water at a concentration of 50/50.
