flashing climatronic
jynx288
hi all does any of you know why the climatronic flashes all 8's when i switch on the ignition?
Stabata
mine does it as well. seems to work fine though. maybe its just because its all digital it needs to set itself before being used
90landrover
308
Rhondda,S Wales
Flashing climatronic control panel is usually a sign that the air con has died a death, mine cost me a fortune to try to repair in the end I gave up and just opened the windows.
bulls20042002
flashing normally means you have run out of gas & you need a re-gas. About £60 should sort it out.
I have to do mine every 12-18 months
jynx288
if there is no gas would the compresser still kick in? or not
Stabata
well you learn something new everyday.
I was told when I bought mine it needed re-gassing but £60 seems steep as my local HiQ does it for £40 last time I asked
