Cupra R back box onto my original cupra tdi exhaust?
CooperC
Hi all :). I was planning to put a cupra R backbox on my cupra tdi but will it be a straight fit or will it need modifiying to make it? Can anyone help? :help:
MJ
Public transport abuser
Apr 22, 2008
5,508
13
Manchester
m.facebook.com
You'll need a reducer because the cupra r exhaust bore is larger than the tdi one and it wont fit into the hole in your bumper perfectly as the cupra r tip is slightly more off set.
CooperC
ok m8 cheers... so do you rekon its worth doing or shall i just keep me standard 1 on?
CooperC
no way how cum mate? does it not sit right in the hole or sumet?
ANDREY_92
Right out and at an upward angle, but in order to make it fit and not bang on the bumper it also had to be tilted.
have you got any pictures on how it looked? because im thinking of getting this exhaust on my 1.6 sx :/ so need to know if its a good idea :D
rallynut
280
ive got a R tip that im going to get welded onto the tdi backbox that should be just as easy if you take it to a Custom Exhuast place and should fit tidy in the hole.
Get yours cut off the backbox and do the same
