Creaking clutch pedal how do i fix it ??
Tamthebam
i have a 2.0 8v gti and when lifting the clutch pedal up it creaks and is slightly sticky any ideas how to fix it , its doing ma nut in :wtf: cheers
Feb 26, 2009
5,275
Wolverhampton
I'm guessing the return spring at the top of the clutch pedal is a bit mucky? WD40 will do wonders.
A failing clutch cable can cause stickiness though, so if the WD40 doesn't fix it, try and look at the clutch cable.
Tamthebam
i'm sensing potential pedal box issues.....mine starting to squeak in the build up to the pedal box snapping.
i tryed spraying wd40 no difference so think its the dreaded pedal box:cry::help: i will have to investigate
cheers for the help
Tangerine_Dream
67
Swindon
mine was the same. I replaced the clutch cable, solved it!
Oh, and my pedal box has split, and been welded (badly) at some point, and has started to split again. i just bolted a bracket/clamp throught the bulkhead, and it doesnt flex anymore.
Aug 22, 2008
3,221
cannock
i know i was talking to stu while reading this and hes gonna have a look at it for me :)
it is starting to feel a bit funny to :cry: she has a few probs atm got to get em sorted,
i hope u havent gone and jinxed me now :headhurt:
