It would be worth logging them in a power run to see if blocks 1 & 2 give the expected results......
any chance you could swap the tthrottle body over from the other car you got the N75 off?
could be something inside that thats not loving it
Dave??
Going to treat me to a new gasket?
Anything else removed apart from the obvious when fitting the mani?...although surely it must be sensor/ecu related if it does it in exactly the same place. I would have said maybe the fuellings dropped with the extra flow but you say fuelling was good on the rollers. PhilW and Benny with k03s maxed out had some fuel pump wonders/issues and changed to LCR/S3 pump and found it better. What map is it running and what fuel pump?
Group A: '114 Group B: '031
Eng Load Call Corr. Load Engine Load Bypas Dut Cyc/0-100% Lambda Factor Lambda Factor
TIME <=150% <=150% 15-150% TIME
STAMP % % % % STAMP
0.37 191 189.6 73.7 0 0.86 0.922 1
1.37 191 189.6 145.1 85.1 1.77 0.992 1
2.17 191.7 191 191.7 85.1 2.57 1.023 1
2.97 191.7 194 178.2 85.1 3.39 0.906 0.883
3.79 191.7 191 182.7 85.1 4.19 0.852 0.875
4.59 182.7 180.6 181.2 85.1 5 0.883 0.875
5.41 176.7 174.6 171.4 79.2 5.88 0.875 0.875
6.3 172.2 170.1 167.7 87.5 6.7 0.86 0.875
7.12 168.4 167.2 162.4 87.5 7.61 0.867 0.875
8.01 162.4 161.2 154.1 87.5 8.52 0.86 0.875
9 154.1 152.2 154.1 87.5 9.42 0.875 0.875
Group A: '002 Group B: '062
Idle speed Engine load Inj. period Air mass in Throt Sens 1 Throt Sens 2 Throttle Pos Sender 2 TPS
TIME 700-820 rpm 15-25% 2.0 - 4.0 ms 2.0-4.5 g/s TIME 3-93% 97-3% 12-97% 4-49%
STAMP /min % ms g/s STAMP % % % %
0.48 2640 77.4 9.18 44.25 0.01 21.5 78.1 30.9 15.2
1.29 2880 146.6 14.62 90.5 0.88 82.4 17.6 54.3 27
2.09 3280 191.7 20.74 138.75 1.7 84.4 15.2 80.5 39.8
2.89 3680 166.9 20.74 130.69 2.49 36.3 63.7 80.9 40.2
3.92 4280 191.7 24.48 165.39 3.41 32 67.6 80.9 40.2
4.93 4720 172.9 20.06 156.42 4.41 38.3 61.3 80.9 40.2
5.73 5120 163.9 19.38 159.61 5.33 34.4 65.2 80.9 40.2
6.53 5440 164.7 20.06 170.72 6.13 34.8 64.8 80.9 40.2
7.33 5720 157.9 19.38 170.81 6.93 35.5 64.1 80.9 40.2
8.24 6040 153.4 18.36 177.86 7.74 35.9 63.7 80.9 40.2
9.04 6280 151.9 18.02 182.64 8.64 36.7 62.9 80.5 39.8
9.85 6480 145.1 17.68 177.06 9.45 36.7 62.5 79.7 39.5
10.65 6680 139.1 17 178.44 10.25 37.1 62.5 79.7 39.5
11.57 6560 47.4 5.1 17.58 11.15 39.1 60.5 79.7 39.5
Hmmm - you can rule out the throttle pedal - it always adds up to 100~
114 would have been good logged with a run that showed rpm - but looks reasonable to me.
What size are your injectors?
No idea mate. Prob the same as your OEM ones.
You're not running a 4bar fpr, are you..........?
RPM IPW IDC
2640 9.18 20.2%
2880 14.62 35.1%
3280 20.74 56.7%
3680 20.74 63.6%
4280 24.48 87.3%
4720 20.06 78.9%
5120 19.38 82.7%
5440 20.06 90.9%
5720 19.38 92.4%
6040 18.36 92.4%
6280 18.02 94.3%
6480 17.68 95.5%
6680 17 94.6%
6560 5.1 27.9%
did you not say that before the mannifold everything was alkl okay and no faults and all you have done is fit mannifold and this happened????
could it be that the new mannifold is causing the car to overboost and hit partail limphome???
