Backdraft
What dyno make is being used?
reason I ask is exact same turbo, 2ltr LC(R), 20vt, cams etc on your manifold etc max'd out the 2871 flow quite early on. DD rollers however. 382bhp from memory 1.8bar peak, 1.6bar (nothing left in it flow wise) - drove nice.. spool and torque felt sweet.
Also has SEM, 80mm t'body, and now WMI also.
you will know of the car Alex
Its on a Maha. I think on Indy's car the cams are not working with the setup very well. Is he still running the BMC? He has RMR rather than SEM.
Adams car is still a 1.8, but has a slightly different flowed head to Indy's and is flowed to the SEM. Not just angled the port, but inlarged. Fould that angling really messed up the flow. Its also running a decat and 2.75" blueflame system.
Just ran the car at 1.8 peak and 1.6 hold, then up to 2.0 peak and 1.8 hold with the turbo still flowing. Will go out for some more runs in a bit, add the meth to the water mix and pop the timing up. Intake temps stayed at 16 degs at 7.2k on every run so far.
