Hi all.
I have a 3" DP & Sports Cat and the time is nearing to put the rest of the system on from the Cat-Back. I will be going custom as I hate the gigantic size of the popular 6"x4" oval that's so common, sorry, so i'll be choosing something a little more understated like the OE tailpipe.
Currently the piping on the car goes from 3" at the turbo to the end of the DP, 3" at the start of the Sports Cat which reduces to 2.5" at the Cat-Back connecting flange and then the OE Cat-Back system is 2.5" all the way through.
From what I understand, the DP & Cats are the restriction on the OE system so with those removed, I should be good to go however, will there be any benefits/drawbacks to the pipe diameter I choose for the new Cat-Back?
I have a choice of 2.5" (matching the rear Sports Cat flange), 2.75" or 3". If I go for a larger diameter than the 2.5" Sports Cat Flange, is this causing a bottle neck or is the change in size between the pipes so minimal that it makes no difference? Will be holding the car back at all by adding a 2.5" system instead of a larger diameter?
