Welcome to our new sponsor Lecatona, a brand dedicated to enhancing performance for VAG group sports cars, including SEAT, Audi, Volkswagen and Škoda. Specializing in High Pressure Fuel Pump (HPFP) upgrades.
hi iv got some 19" lambo wheels for my lcr 8.5 wide et35.just wanted to know what spacer is needed to clear brembo.also is a 225/35/19 or 235/35/19 best.thanxs
pretty sure a 3mm spacer will do, also if you go with a 235 profile on the front you will get rubbing, a 225 profile reduces this greatly and looks much nicer. I will check the ET of my BBS tomorrow as they are 19 x 8.5 also.
Clicky on my sigg for pics im currently running these. Cant remember off the top of my head what spacers im using but will find out. I have 225's on mine at the moment and they seem fine. Not sure how they will be if your lowered as mine is still on standard suspension.
you do need a spacer as the spokes point inwards and will hit the brembo's. Im 99% positive im running a 10mm spacer on the front and a 15mm on back shall check when i get home tommorow.
interesting, must be a design thing so as 3mm spacers do my BBS ch 19x8.5 et30. But surely with an 8.5j wheel and 10mm spacers your wheel will sit outside the arch?
will check and take some pics when i get home today. As said its the design of the fan. If you think bbs ch's curve out where as the lambo's the fans curve back in.
im sure i was informed it had to be atleast if not more than an 8mm spacer the red cupra i think may have been running 8mm spacer which he said was really close. I get home tommorow and will take pics showing distance and spacer's.
