So the Altea's 5.5 year old and hitting 90K, given that VAG diesels seem to be good for 200K + just wondering when and if expenditure for maintenance starts becoming an issue.
I have an Impeccable Service History ( every 10K,)
In the last 3 months it just seems like I have forked out a shed load of cash in maintenance.
* Rear Coil Spring damaged (had to replace 2)
* Re-tyred - (Normal Wear & Tear)
* Replace Disks & Pads allround (First set of Disks, were not MOT failures just getting the RIm around the outside and thin so decided safety came first... Thought 90K was OK on 1 set of disks)
* Replace Cruise Control Stalk (second time)
* Replaced Boot Lock
* Replaced Wiper Blades (First time in 5.5 year)
* Replaced Both Rear wheel bearings (Rumble on One , but changed both, comes as Hub/bearing kit)
* Replaced Head Light / Side Light / Tail Bulbs - (due to couple of failures during winter
No other Issues to report and car still feels tight and solid on the road, Was considering replacing with another Seat TDI (Altea/Leon) but now this batch of mainenance is complete feel I should keep running it, ( i get 30-40K out of brake pads, based on servicing patterns so brakes should not be any issues for at least another 30K)
Had all work above carried out a main dealer as on nice deal with 20-25% discount on parts and 15-20% off labour rates so its not crazy money but its keeping the car with FSSH so if I do move on , makes it mor emarketable , Perhaps!!!
Have I been unlucky with everything coming at once or is above what you would expect with mileage ???
