steve m
80
Hopefully someone can help me, I have a standard factory 6CD changer in my cupra and when I press the button on the head unit is just says changer but doesnt actually work. I have checked it is plugged in fully at both ends and still no luck. I didnt know if there was a way to check if the actual changer is knacked before I try and get anotherone. I know you can change it for a mp3 connection but I still want it working.
I think so :(
If the display said MAGAZINE, I'd suggest it was the cartridge mechanism or laser, but sounds like yours is electrically dead or the headunit just can't see it.
I assume you can still eject the cartridge ok ?
Mine did this for a while. I couldn't get my CD changer or my iPod connection to work. Both would just say CHANGER on the headunit. Just fixed itself after a while.
I think so :(
The cartridge wont eject either, its been like this for a while and it is really starting to p**s me off. I might see if my dads volt tester shows any power going too it, just wunded if anyone has had this problem and if it was just a matter of swapping the changer. Cheers for the replys.
Hi just come across this thread after having the exact same difficulty myself with my mk1 cupra, did you have any luck finding out what it was bud?
I had a look today at the wiring, it wasnt trapped anywhere and there is power getting to the changer. I have hopefully manage to source a new changer and i will try that. I will let you know if that sorts the problem if I manage to get the new changer.
