Windscreen Washers
rebel69
Dark Matter Power
Dec 10, 2009
83
Kent
Silly problem this one my windscreen washers fire about 1 inch above the bottom of the screen. I've tried like crazy to raise the jets but they dont seem to move.
Anyone know how to raise the jets?
Thanks in advance
Reb
Aug 16, 2007
666
Wolverhampton
Is the car new/old?
I had to have one replaced under warrenty for that reason, but I've heard that they can become clogged up and restrict water flow. What do you fill your washer bottle with?
rebel69
Dark Matter Power
Dec 10, 2009
83
Kent
Washers
Hi Cars is a '57 plate washers work fine its just that they seem to fire too low. As the wipers come down first it wipes most of the water off rather than spreading it round the window. Washer liqud is whatever Seat use as they just serviced it and filled the bottle.
Every other ar I've had you could stick a pin in the jet and raise or lower it - are the leon ones fixed in position then?
Aug 16, 2007
666
Wolverhampton
I'll just say that I couldn't adjust mine, there may well be a way to adjust them - i just don't know what it is...
I've noticed that the washer they replaced on mine fires about 1-2 inches higher up the screen than the original one... I'm gonna see if there's any way of unblocking/cleaning them....
rebel69
Dark Matter Power
Dec 10, 2009
83
Kent
washes
Maybe they were fitted upside down?
If your new one is better I'll ry and take one out and turn it up other way see if thats any better.
woody1986
mad as a box of frogs
Oct 21, 2008
106
Derbyshire
i had a look at mine today and it looks like there is two pin holes either side to "stick" a pin in to adjust them up and down!!
rebel69
Dark Matter Power
Dec 10, 2009
83
Kent
washers
Found the pin holes either side but they dont appear to move he jet? will try a "bit more" force
Tried to take the jet out but it wont come loose (slightly damaged plastic [:@])
Since trying to get drivers side out it now sprays about 1/3 of the way up the screen much better - only trouble is cant seem to make the pasenger side do same thing.
