s3 recaros into LCR
s3tle
Yes everything is straight fit, except the door cards.
wow i never know the rears would just bolt in!!
i have been thinking about getting a Leon, indeed i had thought about it a few years ago as well, but have always been put off by the interior and just bought Audi's instead!! being able to change all the seats (front and back) might just of convinced me!
do the rears fit perfectly? around where the door shuts etc? i would be very grateful for any pictures showing this area
thanks
Chris.... soon to be a leon owner i think..... only wish i had kept my uber rare cloth S3 interior now
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
They fit perfectly they look totaly OE, i dont have any photo's of the rears sorry, but believe me if there was any issue on the fitment i wouldn't have fitted them, all the fittings are exactly the same , take the leon interior out and replace with S3, close doors, job done, enjoy :D
I will try to take a pic later today. :)
s3tle
Was it the A3 dashboard in the Leon Mk1 that put you off ??? ;)
:D yeah it actually was!! well more the plastics are just a bit shiney and tacky, fussy i know...
Phill
Thanks for that, i was worried that they might bolt in place but not actually meet up with the other trim, it's great to hear they are a OE fit!
JamJay
California Bound
How about the airbag connections Phil?
Jun 4, 2007
491
Aberdeen
Airbag connections arent the same unless youve got lucky and got straight connections. these need to be changed and to use the heating and electrics these need to be wired in and switches sourced for the heated seats.
I ordered the switches from stealers (problem is theyre for a left hand lcr so wrong way around so need to try and turn covers) and seeing as im ocd lol ordered a proper wiring loom. Have yet to put all this in but when i get home i will be so shall get pics up.
Mark
Jun 4, 2007
491
Aberdeen
not sure on cost exactly is between £65 and £75 but should mean that the electrics, heating and maybe airbag need to look at the instructions. Interior shall be out this weekend hopefully.
daboy3000
No Longer a Seat owner
Jul 2, 2008
710
Oxted
Where do you put the switches for the heated seats, do you replace the cupholder or something?
Getting some leathers at the weekend and i'm sure all leathers are heated.
Jun 4, 2007
491
Aberdeen
Switches replace the cup holder. Pic below only problem as you can see is the curve and flat side are wrong way around.
Im sure i can get the codes of the box tommorow if anyone needs them
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
It would be interesting to see the part numbers you have, mine are:
1M1963563 01C (Left) Satin Black
1M1963564 01C (Right) Satin Black
Quote "Switches replace the cup holder. Pic below only problem as you can see is the curve and flat side are wrong way around."
In the early LC there is no air bag off light you just get a blank, so i can move the blank and the rear window de-mist switch to the cup holder side and then put the seat switches on the right hand side problem solved.
491
Aberdeen
Lol all of us arent that lucky. If only it was that easy for me shall get the part numbers up tommorow.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
there's no option listed for the switches LHD + RHD just one for each side so you should have the same number's as above but let me know what you have if they are different
there's options though for heated window/airbag etc if you need to jiggle em round a bit
