Damaged Steering in Snow.....Help please!
mini670
This afternoon I slammed my offside wheel into a grit bin (it was full too, which is quite ironic), whilst it was on full lock.
Now the steering is out big style, when the near side wheel is straight the offside wheel is pointing out a good few degrees.
Anyone know off hand what this maybe please? I aint got time to look tonight, and would like an idea what im up against when I come to look at it tomorrow.
Any help appriciated,
cheers
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Probably worth replacing...
Suspension strut
Hub Carrier
Wishbone
Track rod end
Track Rod
Unless you're very lucky.
mini670
Thanks mate,
That sounds expensive. Would golf components fit?
Would I be able to see that all those parts are knackered, or would some look ok, but still need replacing?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Some golf bits might fit.... but you're first assumption is correct :(
Some bits will look ok - but may have sustained a stress impact & might break later
mini670
the impact was really slow, 15mph max.
i suppose it it was like 40-50mph it would have knocked the lot off?
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
Might be luck enough to get away with just a wishbone and ball joint but you will need to get under the car for a look.
mini670
yea ill try to get it home tomorrow and have a gander at the components
mini670
It seems the track rod has taken most of the impact as its rather bent now.
Does anyone know if it will require a new rack, or does the track rod seperate easily from the main body of the rack?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Track rod separates easily from the rack... I'd still do the wishbone (and ball joint) though
twig
77
Guildford
I did a similar trick last year with a tree and managed to get away with just the track rod & track rod end. Mine was a lot straighter than yours, mind.
cupraspark
51
Huntingdon
Hi mate you will need a new steering rack - track rod end, i would change the wishbone even if it does not look damaged as it probably is, it might even have a hair line crack. Its not worth the risk mate:).
Its a not a hard job to replace everything, if you are unsure take it to a garage £300 £400 if you are lucky.
Oh and do not forget to use new bolts for your wishbone, as a mate of mine did not and one bolt sheard when he was driving down the road (ford street kakakaka) hope this helps Marc;)
mini670
Thanks for the replies guys, Ive ordered the bits today, should be here tomorrow. Ill let you know how I get on.
ta
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
lol. I don't even look at Haynes manuals any more such is their accuracy.
rack boot off & have a look (though I think it will piss fluid all over you if it's a power rack)
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
lol, i don't need to replace my rods so am not gonna cover myself in fluid just for fun, I just saw the book of lies said it was a specialist job for a dealer.
