VagCom MAF readings
Bobby.Gee
Leon Cupra R 210
Jan 2, 2010
271
VagCom MAF readings from my car today...
Just want to know if there are any problems here and if you can tell if its been mapped here.
My cable keeps preventing me from running full software so these are the only logs i seem to be able to get.
Wednesday 3 February 2010 18:24:45
1ML 906 032 1.8l R4/5VT 0001
Group A: '003 Group B: Not Running
RPM Mass Flow Load Ign. Timing
TIME TIME
Marker STAMP /min g/s % °BTDC STAMP
12.48 880 3.17 2 3.8
12.98 800 2.86 2 12
13.38 760 2.72 2 12
13.78 760 3 2 11.3
14.18 760 2.83 2 17.3
14.59 760 2.86 2 7.5
15.09 760 2.92 2 15
15.49 760 3 2 7.5
116.18 1520 19.08 14.5 21
116.69 1600 25.39 20.8 17.3
117.17 1760 32.81 76.1 15
117.58 1840 36.89 84.3 15.8
117.98 2000 42 89.4 15
118.38 2160 52.11 92.5 13.5
118.8 2320 62.94 96.1 12
119.2 2520 78.39 99.6 10.5
119.6 2720 102.22 100 6.8
120 2960 145.94 100 0
120.4 3200 146.11 100 2.3
120.8 3520 167.72 100 0.8
121.2 3760 169.39 100 0
121.61 4000 170.19 100 2.3
122.01 4240 173.56 100 2.3
122.41 4440 180.03 100 5.3
122.81 4680 184.44 100 3
123.21 4920 190.03 100 4.5
123.61 5120 196.22 99.6 5.3
124.03 5320 204.61 100 5.3
124.52 5520 208.25 100 6
124.94 5720 119 91.4 3.8
125.44 5440 1.44 7.5 5.3
125.93 4640 8.72 7.8 3.8
126.33 4080 10 7.8 3
126.73 3600 8.61 6.3 3
127.23 2880 7.22 5.5 1.5
127.63 2400 6.42 4.7 1.5
128.03 1880 5.53 3.9 5.3
128.44 1400 4.61 3.5 12.8
128.96 1160 3.39 2.7 13.5
129.34 1080 3.44 2.4 9
213.43 1160 18.14 19.6 14.3
213.82 1320 22.08 61.6 12.8
214.24 1520 27.19 68.6 15
214.64 1720 33.36 76.1 15.8
215.04 1920 39.11 84.7 15.8
215.44 2160 52.39 92.5 14.3
215.85 2440 68.25 98 15
216.25 2800 100.53 100 12
216.65 3240 163.11 100 0
217.15 3880 165.75 100 9
217.55 4080 138.94 38 3
217.97 4520 174.69 89.8 6.8
218.46 5040 193.39 100 5.3
218.86 5360 203.61 100 5.3
219.26 5680 208.25 100 6.8
219.68 6000 212.94 100 6
I did a couple of runs within the log.
Cheers Guys...
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
My LC 180 as just pulled 127 g (on my liquid gauge) and that wasn't full throttle.
Post them with the "code" tags around it, makes it easier to read. As below.
Code:
TIME	 TIME
12.98	800	2.86	2	12
13.38	760	2.72	2	12
13.78	760	3	2	11.3
15.09	760	2.92	2	15
15.49	760	3	2	7.5
Bobby.Gee
Leon Cupra R 210
Jan 2, 2010
271
Code:
TIME					TIME
STAMP	 /min	 g/s	%	 ∞BTDC	STAMP
12.98	800	2.86	2	12
13.38	760	2.72	2	12
13.78	760	3	2	11.3
15.09	760	2.92	2	15
15.49	760	3	2	7.5
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
So being a vag com newbie, is the max air flow seen by Bobby Gee's cupra r is around 212 @ 6000rpm, or is that completely wrong?
Bobby.Gee
Leon Cupra R 210
Jan 2, 2010
271
277bhp!
so why do i not feel as if its that fast, is it just me?
i was sort of hoping it wasnt mapped so it would be quicker after lol.
Is there anything else that could be holding it back, I was sure there was a boost leak, still has standard D/V
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
its mapped alright, with some excellent airflow
other things to log of use..
block 020 - timing correction, 115 - request vs actual boost, 031 - fueling request vs actual
logging 003,020,115 common set
001,031,115 also usefull when looking for fueling adjustment
block 032 not log just look at to see what fuel trims are doing.. and if high numbers (>5) then ecu is compensating from something wrong
that kinda thing
Bobby.Gee
Leon Cupra R 210
Jan 2, 2010
271
but if i have 212 and 277 bhp then its still boosting right isnt it?
Or is that something unrelated?
I seriously need a Boost gauge or a full version of Vag Com.
J0N
Defected!
Logging with block 115 will give you your requested boost and actual boost, if there's much of a difference you have a boost leak. The standard D/V is no good though, chances are it's already knackered. You want a Forge 007p with yellow spring.
gezmeister
I need a derv!!
Apr 1, 2008
2,172
Norwich
Don't think you can log past 026 with a shareware version, well, mine doesn't anyway :shrug:
Bobby.Gee
Leon Cupra R 210
Jan 2, 2010
271
its on way but it has green spring...
