brake warping how many of us had it
redrobo150
Newbie
Jul 24, 2006
137
ilson
just wandering how many members have had brake disc warping on there leons
and was it 1 or both disc ,seems to be a few ive heard
and does anyone have any suggestions which disc and pads i should go for ,but not being to expensive butwould give a good performance
im got the price down to 306 pounds for official replacements
thanks
Al
7,331
9
I think mine are finally showing the signs of warping, but they have been on the car from new for almost 30000 miles now.
LeonFR07DSG
400
Hertfordshire
my car has had warped / diostorted discs from when i bought it.... not knowing much about cars really they serviced it and said they were fine...just been sitting around for a bit...will improve...
never have... took it back after 1k miles and they wouldnt replace them under warranty... awesome service... looking at getting better front discs and pads... ferodos are a definate... waiting on a price for the cupra discs...dunno if i need new calipers awell though :shrug:
VADER182
Re djhorace post.........were/are they being replaced under warranty?? If no cant believe that Seat think that 30000 miles is acceptable for brake discs to warp/fail!!! I have owned my FR for almost 12 months and am slightly worried about this VAG group reputation for quality......I think its laughable.......my old Clio 182 (£15000 brand new not £20000) went 65000 miles/five years without ANY problems, and they are crappy cheap French rubbish apparently!!
Big_Mikey_G
146
Birmingham
I had to have my rear brake pads and discs changed on my car at M.O.T this year. Car has done 68,000 miles but since i am not the original owner i am unaware of whether or not they are the originals. The discs werent warped but apparently there were grooves in them!
I have a warped disc on the front however, at low speeds <5 mph i can hear it rubbing against the pad with a squeaking noise. Ill be changing them when it goes in for service in March. Again i dont know if they are the originals or not.
Mike
warren_cox
Back from the dead
My car is in for new pads at the moment, but no noise from Audi as to the disks being shafted (fingers crossed). 34k miles off a set of front pads is more than I got off the LCR (19k)
Inside pad worn to metal, outer pad 80% worn, hence no ABS warning light :censored: Was only when I heard that unpleasant sound / smell I thought better take her in.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
all depends 'how' and 'where' you use em, if i spent all day on the road doing 50k on a motorway a year you could see em lasting 3 years and 300k miles if you never touched em
whereas mine have only done 12k miles but over 5 years it's lack of use for them has killed em
in the past seen some new discs/pads not even last 200 miles and 24 hours on a trackday
end of the day warping can be caused by insufficent maintenance of the caliper sliders -
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
My company astra did 50k on the first set of pads, then at 80k I had new discs and pads. I'm now on 105k in 17 months.
I do prety much all motorway/duel carriageway work.
The only time I have ever warped a pair of discs was when I was younger I fitted a new set then mullered them thinking that, that would bed them in quicker. I warped the poop out of them, fitted yet another set and run them in gently that time.
Tam
Santa in disguise :)
Feb 10, 2005
1,777
Near Reevo :)
had fronts replaced twice now ... and backs once .. thats in 2.8 years and about 85,000
I think braking from triple figures to a standstill (at the end of a runway ;) ) has worn them out quicker :D
Milton Keynes is a ****er for hot brakes FAR too many roundabouts.
Not had them warp yet ... though they have smoked quite often once parked up. :whistle:
