Deleted member 39269
i removed the EVAP, SAI and i relocated the DV just before the TB. i also bought some bits...
Inlet cam for this setup, exhaust cam will change with a bigger turbo
Great build your got going on!
is there much gains to be had with a new inlet cam?
Also how does your can run using the bigger injectors and maf? As im on a K03's turbo and wondering what else can be done to this setup?
