1.2 Spark plugs, help
Bespoke
50
hi guys i need to change the spark plugs on my 1.2 polo, engine code BME (3 cylinder) (Also found in mk4 ibizas - so thought i'd post here)
how the hell do i remove the coil packs if i dont have the VW tool T10094A - This is the tool elsawin says to use.
here a pic taken on my phone
What diy methods have people employed? Do they pull directly upwards??? Push fit style? Is there anything locking them in?
cheers, Scott
st10587
i only brake for cake!!!!
Oct 4, 2007
3,669
Hindhead
yes they pull stright up. if you dont have the correct tool you can use a screwdriver or small lever bar to pop them out
kidinspace
Service Desk Specialist
Dec 3, 2008
1,227
Glasgow, Scotland
www.flickr.com
cheers, Scott
See the torx screw on the left off the black thing? Undo that, pretty sure there is one at the other end, this is whats holding the coil packs down, then they pull out, they are in with a snug fit.
.G.
Bespoke
50
cheers guys, they just feel like they are gonna snap lol!
argh! i am struggling
Rory101
Newbie
Oct 11, 2005
98
I've watched AA men change them on our car a couple of time and they lever them out with a screwdriver. Does make me cringe a bit as they are *very* tight. I'd try to lever gently while pulling the coil straight up.
Remove the electrical plug first so you don't damage the wiring if the coil suddenly pops out.
Bespoke
50
i cant get the electrical plug off though, that stupid black plastic cover for the wiring is in the way
RUM4MO
7,970
1,060
South Scotland
If you are going to use a screwdriver, then try using two - one at each side to prevent snapping the coil assembly. I've heard that a hook made out of welding rod will get in under the coil close to the plug/socket - as close to the coil as possible. Once you have raised them up a bit then create a bit of "slack" in the cables by unclipping the cabling from the retaining clips.
Erentz
I have tried the NGK part finder site but it only gives the standard plugs.
What are the best plugs, because some say Bosch super 4 and others say NGK iridium
RUM4MO
7,970
1,060
South Scotland
On the NGK site is there not an applications guide for "normal" plugs, if you use that then take that info across to any listing that exists for Iridium then you should get a compatable plug. Though, I'm not sure what you are expecting to gain by using the Iridium versions - apart from spending more money! Modern engines, in my experience do not seem to "eat/destroy" spark plugs like some older cars did, I've always just used as VAG fitted at factory - ie NGK but bought the plugs somewhere other than at a VAG dealer's parts place. You will be able to read the NGK referance number off the top of the threaded bit of steel - it will be the same as will be on any correct NGK plugs that you buy else where.
I've used Bosch super 4 plugs on a VX Cav GSI - that car was fitted with Bosch twin electrode plugs at the factory, but I don't think I could honestly say that they improved the car at all (I probably would have claimed they did at the time though!!).
