non vag screenwash problem
Dec 3, 2009
1,638
I got the FR TDi and it says nothing about heated, maybe only a cupra thing! :(
tbh though, I had a lupo with them on and they still froze up..
Mar 25, 2009
1,245
bath
i had a mk4 golf last year and my washers packed up but still made the noise, then it stopped as it burned itself out so needed replacing, my local v-dub garage said it was a common fault when you use TOO MUCH screen wash and it blocks them, he recons he has had to replace the motor on his wifes golf several times as she doesnt let him fill it up lol
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
Have you ever thought that the pipe that connects to the jets has poped off?
It happened to me in two placed before..
Mar 25, 2009
1,245
bath
dunno mate but until you know what the problem is i wudnt be attempting to squirt it, unless you wanna fork out the £80 to get a new pump lol, is it easy to remove the pipe connecting the motor to the jets? if you can then take it off and see if you can blow through it, or squeeze along the pipe and feel for any blockages and if you find it give some good sqeezing to break it down
TazB
Xbox Gamer Tag = TazCupra
Mar 23, 2007
666
Glasgow
i've got some pink stuff from tesco in mine, says it works to -9'c, working fine, except i think the pipe for the back has come off.
si-mate
Jai Ho or Jay Ho?
May 31, 2004
941
Kunt Centryside
I managed to blow a fuse in my Navara by using the washers in the cold. The pump would run for 5 seconds or so then shut off. Luckily it was covered by warranty.
vroomtshh
4,222
Dreghorn, Scotland
Its been pretty cold here -6 washers work straight off the bat every time.
Halfords finest pre-mixed.
Halfords pink stuff in mine too, but temp guage was showing -16 this morning, and as low as -19 in the last few days. Not quite so cold where Scott lives but I was still getting -10 there.
And I 'think' the problem is once its frozen in the pipes (which it will easily do coz god knows what temps are like through the night), the temp will need to go up a fair bit for it to thaw.
I've got a spray bottle with screenwash/water mix in it and i just stop every so often and spray the windscreen with it. Does the trick for me lol
NickyJam
FR - gone, not forgotten
Mar 17, 2008
1,669
SW LONDON
Halfords Pink pre-mixed here too!
never had mine freeze up, even with ice blocks sitting in the plastic housing...works well tbh. Lucky i got 3 for price of 2 recently, just before Xmas ;)
malky39
198
Southside
well i have used cheap stuff and for the second year reunning my rear washer stopped working got it repaired under warrenty but was told seat will only do this once a year and was recommended vw screen wash so bought it stupily from the stealers £9 for 1.5 litres to say i was shocked is an undestatement. Considering i then went into lidl and that had 5 litres of stuff that should work to -60 for a fiver. I will say thought that you can notice the difference between the vag stuff and cheaper stuff it comes out the bottle like calpol
