de-bafferling the charge pipe
wayne lcr
bored of it now
Mar 5, 2009
4,548
doncaster
how do you take the charge pipe off is it just the to clips? or sumthing hidden at the back cos i want to paint mine?
Deleted member 20376
what are the 2 rubber pipes that connect on to it. what do they do?
D.K
LCR 225
Oct 24, 2007
6,408
se london
2 x 12mm (Ithink) nut's on the 2 brackets, 2 hose cliped hoses at each end, then 2 small pipes at the top near the Turbo these are held on with single use hose clips, be carefull when you refit the small 8mm pipe, dont do the new clip up too tight otherwise the pipe will split.
The 8mm pipe goes to the N75 valve
The bigger one goes to the DV.
