piller pods
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
If your sitting in the drivers seat look directly above you and there should be two little panels you need to pull off, under them are screws, remove them and then the whole pillar is then held on by plastic clips and you should be able to just pull if off
ibizaboi
392
Sudbury
thanks dude i will dothat now )
and cruser it does but i wana smooth it all in lol i got water temp and oil pressure wot are u puutin in?
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
Why have water temp? When you already have it on the clocks?
I would recommend oil temp and oil pressure, then I have voltage gauge to watch my tiny battery in the boot lol
ibizaboi
392
Sudbury
lol i see i might change but i already got the gauges soo lol prop wont bother...
how did u guy fix the pod on as mine doesnt wana fit?
Dave_R
Sep 20, 2004
3,666
South Wales
Mine replaced the cd player!
CraigW
Craig.
Apr 12, 2007
4,607
Hawick, Scottish Borders, Scotland
Its Craig btw.
I have got a rev counter to put in, I know I could of just swapped the clocks but I wanted to keep it looking OEM-ish.
I would recommend oil temp and oil pressure, I'll admit I have a water temp on mine but thats because I had a 3 gauge pod and needed to fill the hole lol.
Im thinking of putting a water temp gauge in the centre console because since I changed my coolant tank and thermostat the one on the clocks doesnt move at all, even though all the pipes are warm.
ibizaboi
392
Sudbury
dave that looksmint!!! andcraid im gona put a pod oon the a piller and panitit in cracklepaint 2 "try" and keep oem lol but we will wait and see
