infinityraver
My 02 seat toledo se model has the knobs to control the heat etc. Is it possible to wire in a climate control and would it be a whole wiring operation or a plug in job??
Any ideas???
Bad Luck. SE's usually come with climate control.
It's a big project to retrofit climate control. Lots of sensors in the cabin air system and all the flap valves for directing the air and mixing hot and cold air are replaced with motorised ones.
I sorta guessed that. Its more the cost though of doing it. You wouldnt have any idea how to go about it. Would breaking a scrap toledo with all the parts be the best idea? Would it require air con pumps etc or would the ordinary cold air fans do ok?
If you don't already have air cooling ( an a/c button on the heater panel, I think) then you have a much harder task. You will need the cooler, so there's the compressor to fit, needing a new "fan belt", then the condenser, all the pipework, and the evaporator in the cabin air duct. You would probably have to fit a new set of air ducting so as to fit the evaporater in (the cooling bit - it sits in the ducting between the fan and the heating matrix). All the cabin air passes through the cooling matrix, then temperature control is done by diverting some or all of it to the heater. That's what dries the air and makes it good for demisting - cooling it drops out all the moisture, then heating it up again makes it drier.
I have no idea if the loom has the wiring you'd need or if you'd have to add in new wiring.
