Turbo upgrade what should i expect
jeggy
HI there, i have just bought a car and currently it has a
KO4 Hybrid on it
Forge Front Mount
Big Port Manifold
4 Bar FPR
3" downpipe mated to a Milltek
with Cone Filter
what do you think i should expect. car had 285 on its last rolling road, felt it should have a wee bit more than that. Also what could i add to this to squeeze more out it cheers
J
jeggy
should it have any more than this its a Leon Cupra R its all fitted to
J
jeggy
yeah thought that must be something causing it to loose it may require a new map anyone got any ideas of upgrades with the kit i have
jeggy
The Map Was done by awesome Gti its one of the program maps through the cruise control still dont know what each setting does lol.
jamiebennett81
first place I would start is get it on VAG COM for any obvious issues i.e. a tired MAF, which may be causing your car to be under reading
dependant on the map though, could be quite a conservative map, so actually nothing may be wrong with it at all
jeggy
its been on Vag com the only fault that is coming up is the Lambda Sensor as the cat is missing apart from that all seems ok
jamiebennett81
not only this
get some VAG COM logs done i.e. measure req Vs act boost, g/s etc
failing that, I would put it down to the map
