reading that thread there seems to be quite a few problems. as this is my first car do you think a ford fiesta mk6 would be more reliable or are the
ibiza generally reliable
First of all, you have to expect some wear on a car after 74,000 miles
I had a mk6 fiesta as a courtesy car for 5 long days. All I can say is that it was awful, worst thing about it was that driving it at 70 on the motorway was scary, blew all over the lane and couldn't make it drive in a straight line.
Value for money wise the
mk4 ibiza is a good buy, nice and stable to drive, plenty of room in the front and has a good boot. Although the ride would be slightly harsher than other cars.
Just make sure you give the car a good look over before you buy it. I have found my 1.4ibiza perfectly reliable. They just have a few characteristic minor problems like the misting headlights and other minor things that can commonly happen in the car's life such as the rear wiper pipe popping off (can be easily checked). As far as fuel economy I can easily get 45 - 50 mpg from my 1.4, but depends how angry i am
The car is basically a polo in disguise with Volkswagen parts so nothing major generally goes wrong with them. Replacement parts can easily be got and arent expensive, plus this forum is brilliant, there is always loads of ppl happy to
help with any problems.
Like any car you go and buy, do all the general checks and make sure she is running sweet first and then check for the common
ibiza problems. Make sure the rear wiper washer is working, try and take her for a test drive over some bumpy roads to make sure the suspension isnt too noisey/ rattley, i would advise you to make sure the fan heater blows both hot air and cold air and that the air conditioning works. There definately should be no fault lights on the dash after starting.
I would highly recommend an
ibiza, and they are worth a look at.
Good Luck
