aterro
Banana Bomber
Oct 28, 2009
118
right
im using the green nipple for my boost gauge
which way do i route it?
i carnt seem to find a hole in the drivers side at all?
and where does it come through the dash so i can find it?
push through gromet on passenger side by header tank;)
thanks
is there nowere i can push it through on the drivers side?
as i dont have enough hose to go to header tank then to pillar pod?
ive seen a few people put it through the top left hand side where the front wipre mech is?
but where does it come out?
and which hole should i put it though?
also is the green nipple a bad idea?
and best to use the dv line? or what?
thanks for all the help lads
right mate i had it in wing first off . so it comes off green nipple around washer bottle follow bonnet cable so its tucked away and i put through wing through door gap inside into gauge hidden away niceley
Ive got mine T into the fpr hose. works fine.
Ive run it up past the washer bottle up next to the ecu theres a grommet where the bonnet cable goes then it comes out inside the car under the steering wheel where the fuses are...
I admit I am being a lazy bones and not searching, where is the best place to plumb a boost gauge in for the most reliable reading of vacuum and pressure? As I was thinking t-ing into the vacuum pipe on the top of the dump valve?
