thanks. Ive just been reading up on fitting them. i have plenty of places to put the ballast as my engine doesnt take up much room being a 1.2, If i want to hide it that could be interesting.
Follow the link in my sig to see what I done with mine, I have to replace my left hand headlight unit so may put them somewhere else then. To adjust them there are two white screws on top of the headlight unit on either side, use a allen key to turn them. Important to note the one on that is nearest the centre of the car is the one that'll move the beam pattern up or down.
On the image below you can see the back of the adjuster to the left edge of the photo, the allen key position is out of view on the top headlight unit. If you have a look yourself as to where they are it's quite easy to see.
Best to park about 15ft from a wall like I did to check and photograph the beam pattern first with the halogens to replicate it with the Xenons. When doing this put the bulb adjuster in the car to "0" so that when you put the Xenons in and replicate the beam pattern you'll know that even on the highest setting you won't be blinding people.
I still have to get a photo of the re-aligned Xenon's against the same wall to show the adjustment.
.G.
