can't remember which does what so ill name em front and rear for reference but ill try and list all the ratios+numbers i can find
petrol EDT/EWP
36/43 =
0.837
Rear 02A311361L
Front 02A311158H
diesel 110 EKW/EWZ
29/39 =
0.743
Rear 02A311361AD
Front 02A311158AE
diesel 90 EKU/EXA
33/46 =
0.717
Rear 02A311361M
Front 02A311158R
all i can confirm is the 5th gear syncro hub and collar assy is the same for all 6 trans so i can't see a reason why not on paper but as usual tools wise is a different story but at least the ratios may
help a paper exercise to see if it's even worth considering ??
wierdly the petrol diff ratio isnt listed due to changed parts (confirmed replacement part numbers to be 61/18=3.38) the tdi has a choice shown with no confirmation of two choices which is different ill admit
60/19 = 3.15
61/18 = 3.38
but anyway i know the diff ratios won't be relevant for this project as such just adding it to see what difference the newer ones had compared to the mk2 i looked up before
as said above this is merely an idea off the top of my head and i have no 'real' idea as to wether these gears will fit straight on and do the job intended as i haven't yet had the pleasure or done the maths and don't have all the right pieces to hand sadly
