okay guys, reversed n249 bypass today, id say it feels better oem than bypassed on mine..
anyway, i had a whistling noise on boost, to accompany the whine i have aswell on low revs, kinda hoped the re bypass would make it dissapear, but to no avail
any ideas on whistling on boost? quite high pitched aswell.
prefer the dv sound un bypassed and no more turbo stall kinda sound which was there on bypass. im gonna do some logs to see if theres any differences, but for now any ideas on the whistling.
while your here... went out for a razz after i did the re bypass, pulled over, checkd connections, all good.. noticed a crackling sound coming from behind the block, near the turbo/manifold.. like a open fire crackling sound as if something was mega mega hot?? what could this be and is it normal?
im thinking, exhaust downpipe gasket or turbo gasket? could this also be contributing to the whining noise...
from my vagcom logs, all seems ok, other than some slightly high timing pull, and running slightly lean aswell... pointing towards gasket failure??
sorry for the long winded post
, just after this sorting asap.
