homemade TIP
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
This for a k03 fella.?
Id say 45mm 90degree reducer to 63mm then past the gearlinaage step it up to 76mm....Then a coupler reducer on to the maf...
The Dv ports are required to be 25mm (1'') and the evap would be a 5mm self sealing bung along with the Vac & n75...
Tbh unless u have all the Evap & n249 ect done it would work out more expensive than a forge tip as the bungs are around 20quid each...
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
And 19mm port for the PCV system.
& that too...
Works out more expensive if you've got all the OEM bits in place...
This is the one i made for the IHI....Pointless on doing it on a k03x unit...
2,958
Wiltshire
Mine's now made up from (bottom to top):
1x 45-51mm 90 degree silicone hose
1x Revotec 76-63-51mm stepped aluminium reducer
1x 76mm 90 degree silicone hose
1x Revotec 25mm hose take-off for DV return
1x Revotec 8mm hose take-off for N75
I've binned my EVAP, SAI and PCV so I didn't need any other ports
