It could be the charge pipe, I'v just fitted a de-baffled one to mine and it has made it sound deeper at low revs.
Did mine today, with before and after VAGCOM logs. Difference? Absolutely ZIP! lol. Not driven much to see if response is better or anything, but I'd personally say a lot of effort for next to bog all so think carefully before doing!!
Surely it's worth it just for that low down growling noise?
Or was that just lunch?
haha yeah, drilling yeah, smoothing... waste of time and effort
The argument as to downsides is opaque as some would argue that it can allow warm air from the bay into the system however on the other hand there are people saying that it doesnt matter because of the turbo super heating it and the intercoolers cooling it down afterwards anyway.
surely, if drilling holes in the airbox is goingto allow warm air in then the cone will have this same problem but due to its shape , it will suck in more warm air as there is nothing from preventing it from sucking in the warm engine bay air. the drilled box atleast has some protection as the holes are at the bottom and not a lot of warm air will be sucked in due to the locations of the holes.
True, but the box is more constricting, the amount of air will be lower full stop. I have used an open cone and put a cold air feed coming up from the foglamp port. You can also get temperature shields for the cones. I don't see how a drilled box would ever be better than a well thought out cone with good cold air feeds.
