warning light on!!!!
Ryeh82
Newbie
Sep 20, 2006
64
bradford
hi all, been noticing this week coolant temp been rising above 90 every now and again.until today when it went to 120 and warning light came on!!been up and down since. Car is Cupra 180 02 plate. any help ? cheers.
Grimster
Had same sort of problem when the aircon packed up - found that the fuse under battery cover had blown. Replaced fuse and aircon started working again and now running very cool. In fact my leon runs usually around 75 and only goes up to 90 when sitting in traffic!!
meltonlad
391
huntingdon
you could try a few things like..... when the temp gets hot check to see if your cooling fans are working but turn your A/C off first.... also you could do the secret climate control settings.
Ryeh82
Newbie
Sep 20, 2006
64
bradford
mine is normally always 90.But on way home today hit 120 so pulled over and it went
back to 90. sometimes a petrol smell in car when heating on too. not sure if thats linked to it?
meltonlad
391
huntingdon
mate i just seen that you are in bradford.... if you want i could meet you some where and plug it into vagcom thats if you not got it.
Ryeh82
Newbie
Sep 20, 2006
64
bradford
cheers mate,not gonna be able to meet tonight. maybe 2mo after work if o.k? was gonna take to garage on fri,but if could find fault before would be great. where in bradford are you?
meltonlad
391
huntingdon
im near idle mate. i maybe able to do 2moz but it would have to be after 7.30pm or could leave till thur if u want ? do you know the hitching post pub ?
Ryeh82
Newbie
Sep 20, 2006
64
bradford
after 7.30pm is fine unless thurs is better for you?i finish at 4.30 thurs. not sure where that pub is?is Morrisons near you?
