Helix clutch kit
nikstar
80
I am currently looking at clutch kits with SMF, does any1 now the weight of the SMF that comes with the helix clutch kit?
Aug 1, 2005
2,695
Cullompton . Devon
Hopefully things will start moving again as the gearbox company i paid to strip and rebuild the gearbox screwed up which wasted 3-4 weeks waiting for new parts to arrive before they could rebuild it and get the the engine fitted. Going to see it on Tuesday so i will take some pics.
mymorph
417
wolves
hey devonmb 10/10 for maxing the tdi. its beyond me wot you do with the propane and i reckon a cryo engine is frozen real cold to be reborn wot hot baby doll[:@]...
love to see/hear a movie clip or two.
Aug 1, 2005
2,695
Cullompton . Devon
Propane is injected as another fuel on top of the diesel. Larger diesel injectors are a better way to go to flow more fuel but bigger injectors have only been available in the past twelve months for my BKD engine so used propane as a top up. If the new uprated nozzles flow enough fuel with the methanol i am injecting hopefully i might be able to remove the propane kit to save weight and try to simplify things else i will be injecting three fuels ( diesel,propane,Methanol ) plus NOS :headhurt:. Cryo Treatment
nikstar
80
devonmikeyboy, just out of cuorisity, what clutch did you run in ur ibiza, what have you been running in the A3 and what are you going to be running once all rebuilt, oh and whats you opinion on them?
Aug 1, 2005
2,695
Cullompton . Devon
I used a Helix with SMF on the Ibiza. On my Audi is a Spec stage 3+ with SMF which hopefully should hold otherwise i will have to fit a twin plate clutch.
