It just peaks to aroun 0.85bar and starts tailing off. Guna get the map changed as my last result.
Thats a very mild map if it only peaks at 0.85bar (12.3psi). How much boost does it request?
Group A: '003 Group B: '115
RPM Mass Flow Load Ign. Timing RPM Load Absolute Pres. Absolute Pres.
TIME TIME
MARKER STAMP /min g/s % °BTDC STAMP /min % mbar mbar
0 2160 36.75 100 13.5 0.4 2280 92.5 1880 1250
0.82 2360 53.25 100 5.3 1.31 2560 124.1 1890 1680
1.71 2760 70.58 99.6 6 2.11 2920 133.8 1910 1810
2.51 3080 80 100 10.5 2.91 3240 139.1 1870 1830
3.31 3400 91.78 100 9 3.71 3560 139.1 1840 1840
4.11 3760 97.5 100 12.8 4.51 3920 137.6 1860 1820
4.91 4080 108.92 100 13.5 5.31 4240 138.3 1850 1810
5.71 4400 119.64 100 15 6.11 4560 142.1 1830 1810
6.51 4680 130.78 100 12.8 6.91 4840 145.1 1830 1820
7.31 5000 138.03 100 14.3 7.71 5120 144.4 1840 1820
8.11 5240 142.83 100 12.8 8.51 5360 140.6 1830 1800
8.91 5480 142.78 100 12 9.31 5600 135.3 1810 1790
9.71 5680 144.08 100 12 10.21 5840 133.1 1790 1740
10.72 5920 146.89 100 13.5 11.12 6040 129.3 1730 1720
11.52 6120 149.47 99.6 12.8 11.92 6200 127.8 1440 1710
Im guessing youve spoke to AMD about it...??
Why not take it to them to have a look at..?
Did ring them up to enquire about it, they say about right. Just dont have the time to drive up there as i need most of the day to do it.
Gettin a alternative map this week so hopefully, this should insreaces it.
Yea dont see how it can be about right if my one peaking at nearly double that...and the same with 95% of other stage 1 maps..
Well if you exhausted every other option then spose it could be map related...
mine reads 25-26 hg when warm on idle where is yours plumbed in?
i got mine running from brake servo hose on left side of the engine just cut off green cap and run it from there much more accurate
