1 second audible warning!! help?
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
I've looked at past posts for info but no answer to this,
I get a warning buzzer with no lights coming on on the dash. Sometimes on start up , usually at low speeds, but had it on approach to motorway doing 50. Only happens once a week or so, then nothing for days.
Not my pads as they are relatively new, coolants topped up and have washer fluids. I don't have hand brake on either. I'm baffled!! :confused:
Any one got any ideas?
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Sorry, been hard at it, thanks, coolant level fine, could be a low fuel malfunction?! Not sure,
Definately not hand break as it's happened while on the go.
Trying to get hold of vag.com on monday, Im not too tecky though, so could be a bit of head scratching!!
Joe K
52
If you get vagcom it is simple to use and we all can help with the fault codes .. you can buy the lead and program from the bay ....
mikeholroyd
It's not a low temperature warning on these cold mornings, is it? My Leon gives a single bleep when the temperature is below 4.5 degress outside.
Mike
