looking lovely mate!
can't wait to hear this when finished mate!
if you look at the original inlet, you can see where the throttle body is located (on the left) and when open there is "x" amount of pressure, but then this is then split into 4 (each cylinder) so then it's "x/4" per cylinder
but as the bike carbs won't do this, so has better pressures (well bigger) so can add alot of power (for a N/A car)
Ah cool, is that similar to individual throttle bodies?
Updatings
Engine bay painted :D
Before:
Primer:
didnt get any after photos, but its all painted black and laquered now also :) got a bit dark towards the end
Few more pretty things arrived :)
Had a fair few bits powder coated gloss black, including all the brake system, rocker cover, and brackets
The main Brake bracket looks amazing, like new, and im really pleased with how the rocker cover came out
Rocker cover:
Brake bracket:
Also made the vacuum nipples fit for the advance on the ecu:
sweet!!!
coming along nice, can't wait to hear it mate, better be vids :p
what's the total price for the actual bike carbs? (not including painting etc, just actual bike carb related)?
Bike carb costing:
Bike Carbs £49.00
Inlet Flange £32.00
Stainless inlet pipe £15.00
Inlet welding £45.00
R1 Fuel Pump £25.00
Silicone hose £15.00
Inlet manifold gasket £3.00
Vacuum Nipples £8.00
Brake servo nipple £3.50
vacuum Hose £3.00
choke cable £8.50
Fuel T £2.80
Cable adjuster £3.50
Solderless nipples £6.00
Electrics to run the carbs:
Distributor and Loom £25.00
KR Controller £26.50
Distributor Cap £10.00
If you can get all that then thats all you need for the conversion :)
Obviously prices may fluctuate, like the inlet i made myself so ended up costing just over a hundred quid which isnt bad at all considering bogg bros sell them for over 300...
Youll need a kr distributor from a mk2 golf gti 16v, and the ecu off the same engine, and the bike carbs are from a ZX9R
thanks for that mate, so say £400 for the lot, that's impressive mate! i am so tempted, when/if i save up, no doubt i will be picking your brains :p lol
can't wait for this to be done mate!
Nice conversion for the engine but shame its on the clean mk1:(
Should be kept original...ah well another pice of history gone:ban:
very nice mate. Really like that you opted for something a bit different going with the bike carbs. I am a mk1 man myself too, so can definately appreciate this.
However as said, 4 lights...no.
was wondering what gearbox you'll be using? It was already a 5 speed because it was a gti, but are you now going for the one that came with the new engine or what?
